how to read data from txt file respectively
Ok, here are some tweaks.
  1. Use Read from Spreadsheet File to get your values.  It is a little cleaner.
  2. Do not keep opening a file inside of the loop.  Open it once before the loop and close it once after the loop.  You can then read/write to it as much as you want inside of the loop.
  3. I really like to use Format Into String to put my values into the desired format to write to a file.
Message 11 of 11
(241 Views)
