how to read particular number or word from lengthy serial data
Serially getting lengthy data...how to get particular number or word from Tht
Message 1 of 8
(3,625 Views)
Could you be more specific?
Message 2 of 8
(3,619 Views)
And possibly an example?
GCentral
Message 3 of 8
(3,607 Views)
I am getting continusly 3 measured voltages,currentso,powers over serial through a device with 921600 baud rate ,at every 500 mSec ...I want to read the particular data ..those values over serial are separated by spaces ..
Message 4 of 8
(3,600 Views)
Again, you need to be more specific.....
what EXACTLY is contained in the string.  Give us a specific example of the data you need to split.  There are a wide number of waits to split information in a string but we need to know the start and end formats to help you.
Message 5 of 8
(3,593 Views)
@Omi_30 wrote:
I am getting continusly 3 measured voltages,currentso,powers over serial..those values over serial are separated by spaces
Are the numbers in ASCII?  Use the Spreadsheet String to Array function.  Wire in a space constant to the delimiter and a 1D array of doubles to the array type.  You can then use Index Array to get the value you want.
GCentral
Message 6 of 8
(3,589 Views)
I will be getting the data shown in screenshot continuously at every 500 mSec from my device. I need to take particular voltage measureent value for accuracy check. So I need to save the data coming over serial to Excel / text and read particular value for further analysis.
Message 7 of 8
(3,558 Views)
Message 8 of 8
(3,557 Views)
