how to read synchronously two encoders in cDAQ9178
I  want to read two encoders connected to cDAQ 9178  (counter0 and conter1) via NI9401 module. My problem is  how to read synchronously these two encoders. I have Labview 2009.  Maybe somebody has any template with  the program  which could be useful for me.
(2,944 Views)
A quick google search led me to this example.
{LabVIEW}\FPGAWizard\PlugIns\Function\niRIOQuadCtr\Templates\Fpga\QuadratureCtr_X4.vi
I'm guessing you have to wrap the encoder boolean logic in a subvi and drop two of those subvis on your block diagram.
You could then, at some interval, take the position outputs from those algorithms and drop them in a target to host FIFO to get simultenous data.
Sorry, I just noticed you're using a CDAQ.
Here's a starting point. YOu have to add another similar channel to your task and use the N Chan 1 sample polymophic read
{LabVIEW}\examples\DAQmx\Counter Input\Counter - Read Encoder.vi
9401 doesn't have any counters. You're going to have to post process your data with some delay. See:
https://decibel.ni.com/content/docs/DOC-4170
(2,930 Views)
