how to read the data from TDMS file??
Hello everyone ,this is bharat . I am fresher to labview and learning basic labview.
      Anyone can suggest how to read the data from TDMS file, in that lack of data is there . I want to read the data and should show  the graph of those data.
(13,161 Views)
Accepted by topic author NI0022818
Hi bharat,
The general method of getting information from a TDMS file is 1) Open file using the file path, 2) Perform read operations as required, 3) Close file.  The tools for this can be found on the File I/O - TDM Streaming palette.
For example, here is how to read the contents of a TDMS file:
And here is how to read waveform data from a group:
You can also use the TDMS File Viewer from the TDM Streaming palette to look at the contents of a TDMS file.  If you look at the LabVIEW help for these tools you will find more useful information about how to use them.
Andy
(13,132 Views)
There are also free plug-ins for Micro-Soft Excel and MathWorks MATLAB:
Excel:         https://www.ni.com/en/support/downloads/tools-network/download.tdm-excel-add-in-for-microsoft-excel....
MATLAB:    https://www.mathworks.com/matlabcentral/fileexchange/30023-tdms-reader
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(13,097 Views)
thank you for your great suggestion.
(13,072 Views)
