how to read values from specific pins??
Hi there,
I am currently doing a project that requires me to perform some performance verification, if i want to read values (voltage, Frequency and clock cycles) from specific pins? is there a way to do it?? I am using DAQ NI PCI 6024E.
(2,842 Views)
What pins you are talking about? The inputs of the DAQ card? You have analog, digital, and counter inputs. There are example programs that come with LabVIEW for making all of these measurements.
(2,834 Views)
hi
Thanks for the reply. The connector pins (68pins) that use to connect the external device.
(2,823 Views)
Thank you so much!!!! i was looking for the training as well! Thanks for the info!
(2,798 Views)
