how to readback lvbitx version from compiled file?
The build specification for an FPGA lvbitx file allows you to set Version numbers (Major.Minor.Fix.Build). However, I cannot see how to read this information back from the compiled bitfile. With a DLL you can right click in windows (W7 64 bit) and properties -> details shows the version. This does not work for a lvbitx file.
Andy
(3,540 Views)
Accepted by topic author Andrew_Quick
If you open up the bitfile in a text editor you wil see that the first part is actually just XML.  You should be able to parse the version from there (3rd line or so).
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(3,529 Views)
