how to reboot RT programatically without using the VI
I have a bunch of PXI RT systems deployed. We setup an IVI looking interface for our client monitor systems to the PXI RT systems, this is over enet.  Other than snooping the network activity, can anyone provide the command structure needed to send the reboot command to the RT systems?  We can NOT use the included labview VI because some of our clients are running VxWorks.
Thanks!
(2,748 Views)
Hello JFTICH,
For any PXI Real-Time systems that have LabVIEW Real-Time, the VI you spoke of will definately work.  It sends the command to the specified PXI systems.  After looking at the VI, I see that it is locked.  The way that it creates this functionality is protected for some reason.  Perhaps you could contact National Instruments Support for some more information regarding its method of operation.
You can create a service request here: ni.com/support
Steven T.
(2,733 Views)
