how to receive data via tcp/ip data socket
Hi
         i have system with labview 8.5. And one of my tcp/ip device is placed remotly. It's a modem to read data from plc using modbus protocol and send through sms, email, tcp/ip socket. its doing well. its has tcp/ip datasocket connection option(i.e.IP, port, username, password).
So i want to read data from modem. Will it possible to read data via labview data socket ?
Pls Help.....
Message 1 of 11
(6,186 Views)
Hi bosski,
It should be possible to connect to it using LabVIEW.
Can you give more information? What type of modem do you use? What have you tried so far?
!Please open only one Thread per Topic!
Mike
Message 2 of 11
(6,179 Views)
Hi Mike,
Its a gsm/gprs modem. it reads data using modbus protocol from modbus enabled devices (Like PLC, VFD, etc) And it send this data as Hexadecimal string via SMS, E-Mail and tcp/ip socket connection.
i am going to place this modem in remote site, and receive the data from remote site via labview data socket.
After that i will insert the data into database.
i have no idea about data socket, but eager to learn.
'Sorry for the duplicate post'
Thanks&Regards,
Bosski
Message 3 of 11
(6,171 Views)
Hi Mike,
Thanks&Regards,
Bosski
Message 4 of 11
(6,165 Views)
Hi Bosski,
which type of server is running on your device? Is it a TCP/IP Server? If yes, then you can also use the TCPIP function. Connect to the server and read and write data from/to it.
Mike
Message 5 of 11
(6,160 Views)
Hi Mike,
I think its not a server. it opens the tcp/ip port connection of given ip address
Options in modem,
IP address:
Port:
username:
password:
Message 6 of 11
(6,158 Views)
Hi Bosski,
where can you now see the information like IP Address, port, ...? I think there is a tcp/ip server running, and you can connect to it. See the tcpip examples in the example finder. You can use the Client example to see what you need. Which information do you want to get over your tcpip connection?
Mike
Message 7 of 11
(6,151 Views)
HI Mike,
 (IP, Port, Username, password)--->I found in modem configuration window
Message 8 of 11
(6,149 Views)
Hi Bosski,
where is your configuration window, do you see it in the browser or is it a seperate program? Please also answer my other questions.
Mike
Message 9 of 11
(6,143 Views)
HI Mike,
see the attachment for configuration window of modem.
'Which information do you want to get over your tcpip connection?'
i want to know whether i have to tci/ip or data socket ?
Message 10 of 11
(6,130 Views)
