how to remove a number from a list controlling a table
i'm controlling data that enter to a table by using a specific one from them,let's call it "number of the user", when a client has the num 5 and enters his data ;it will be stocked in the 5th row.i want this number 5 to be removed from the list ,so when a new user try to enter num 5 he gets a message"number already used" so he have to enter a different number than 5,for instance 8,consequently i'll get all his data in the 8th row.
if anyone know a little trick to solve this problem
thanks
Message 1 of 22
(3,949 Views)
Delete from Array will remove an item.
That or maintain a boolean array that will tell you if a number has been picked before.  If element 2 is picked, the check if element 2 of the boolean array is True (already picked).  If it is False (not picked), the act on that data and set that boolean element to True.
Wash, Rinse, Repeat.
Message 2 of 22
(3,943 Views)
Hi archifire,
 Please have a look at the block diagram where student details is implemented a table.
SrikrishnaNF
Srikrishna
Message 3 of 22
(3,923 Views)
There is no need to keep track of anything seperately. Simply check if the requested row has already been filled or not.
Message 4 of 22
(3,895 Views)
adding to others...
  • check your specific column of data
  • compare empty string of each row using 'for loop'
  • index out the results
  • fill your drop down list of available user #'s
Message 5 of 22
(3,863 Views)
this number has to be a shared variable,every client is concerned .
"There is no need to keep track of anything seperately. Simply check if the requested row has already been filled or not." i'm not sure if i get your point,because i don't want a new user to even try to fill data in same row,for example 5,the moment he enters 5 in "NR_ORDRE" he gets a message"it's already taken" or use a combo box containing numbers when a client use one it gets deleted for the upcoming client.
Message 6 of 22
(3,828 Views)
would it be better if i replace it with a combo box and fill it with numbers from 1 to 100 ,but i'll need something to remove a number from a combo box when it's already used by a client >> unique number for each client
Message 7 of 22
(3,799 Views)
Wouldn't it be more useful to instead keep a list of rows that have been used?
Message 8 of 22
(3,790 Views)
how to do that Mr altenbach,by the way i posted the vi in my previous post if you need to see what i'm talking about
thanks
Message 9 of 22
(3,779 Views)
Message 10 of 22
(3,740 Views)
