how to remove only one row from the database using labview6.1
using labview 6.1 I create a table with various rows and columns and store bulk of data's in them.,, what procedure should I follow to remove only one paticular row from the database? Help me out with an example please,,
Thanking you in advance!
(4,656 Views)
If you have the database toolkit you can delete a row using just a SQL Query to "DB Tools Execute Query.VI"
Example:
DELETE FROM Table name Where SerialNum='Value' And Date='Value' And Time='Value'
See also attached VI
Best Regards
Johan
(4,656 Views)
Thanks for your suggestion! I'm able to solve my problem,,
-Lalitha
(4,656 Views)
Hi lalitha,
 how to remove database row if you have any vi please post here .
Thanks advance...
Regards
Arunkumar
India
(4,123 Views)
1. This is an 11 year old thread
2. This is already answered in your other post
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,092 Views)
