how to rewrite the dll file
EpromW(TCHART Efile[],HWND,hWnd)
Efile is the file name to test, hWnd is used to graphic the progress Bar,
For the first TCHART Efile[],I want to open a file that I want to write it into my instrument, hWnd is a progress Bar that can indicate my process,but when I use the Call dll function node, it can't write it correctly.please give me the best resolution.
maincool
Message 1 of 16
(4,016 Views)
maybe you need the terminator "\n" at the end of the test file string. Just a thought.
Message 2 of 16
(4,003 Views)
Joe Guo 写:
It can't write it correctly,please give me other advice!thanks a lot!
maincool
Message 3 of 16
(3,989 Views)
Please provide us with the prototype of a call to the DLL in a text based language, including type descriptors. That would make it easier to determine how to call it from LabVIEW.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 4 of 16
(3,976 Views)
Also, take a look at the excellent shipping example called "Call DLL.vi". It shows the ways to call almost any data type.
Thinkbot Solutions
Message 5 of 16
(3,971 Views)
Hi Philip:
Philip C. write "Also, take a look at the excellent shipping example called "Call DLL.vi". It shows the ways to call almost any data type.
Please provide us with the prototype of a call to the DLL in a text based language, including type descriptors. That would make it easier to determine how to call it from LabVIEW. "
The based language is the VC++6.0,the description as below:
EepromW(TCHAR Efile[], HWND hWnd)
Select EepromW to programme at the start/end of the test (after I2cCommOpen)
Efile[] is the name of the file ,
the hWnd is the process bar ,
Also there is another to check it status
The method SInfo to check the status of write Eeprom:
struct SInfo {
BYTE status; status of the process (Eeprom Dawnload Status)
BYTE perc; percentage of the process (0 - 100)
BYTE err; error code (see ERR_CODE in Sbit100.h.)
BYTE nRetry; n. attempt (1 - 3)
how to call them?
Thanks a lot
maincool
maincool
Message 6 of 16
(3,967 Views)
Use the following types when specifying the parameters of the DLL in the Call By Reference Node:
Efile: String >> C String Pointer
hWnd: Numeric >> Unsigned 32-bit Integer
See the attached DefineDLL.JPG.
Thinkbot Solutions
Message 7 of 16
(3,944 Views)
Philip C. 写:
Thanks a lot!
Yes,first I invoke this dll, I use the specifying the paraemters like you said, but I want to see the progress bar during my program running,how to do it?
maincool
Message 8 of 16
(3,941 Views)
maincool 写:
Philip C. 写:
Thanks a lot!
need I use CIN tool to configure the DLL configration?thanks a lot!
maincool
Message 9 of 16
(3,913 Views)
Hi Maincool!
It sounds to me like you're not necessarily having any troubles calling the function (in the DLL) from LabVIEW. It sounds like you are having troubles getting the functions in the DLL to do what you want them to do. It is hard for us to tell you how to get it to work because none of us know what functions reside in your DLL and how they all work together. However, I'll take a stab at it.
It sounds like you may be loading the progress bar into memory and configuring it just fine. It also sounds like there should be a function to *display* the progress bar. Could this be the case?
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
Message 10 of 16
(3,894 Views)
