02-20-2013 07:01 AM
I'm trying to rotate an imaq image. I have seen I need to use "image manipulation.llb" to do so. where can I find it?
thanks,
Gilad.
02-20-2013 01:15 PM
This may be similar to what you mentioned but have you tried using this VI:
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_rotate/
--Ryan S.
02-20-2013 02:13 PM
do you have the vision development module installed?
03-13-2013 08:30 AM
No. I don't have this module installed. is there any other way to do so without using this module?
03-14-2013 04:56 PM
To use the IMAQ Rotate VI you would need to have the Vision Development Module. There are other ways I can think of, but you would need the Vision Development Model to try them as well.
03-14-2013 05:06 PM
If you can convert the image to a PNG file, you can load it and rotate it using the standard LV picture control. You can see an example here - http://forums.ni.com/t5/BreakPoint/LV-Picture-Control/m-p/230351#M748
