how to round up or down to the significant digit
instead of nearest integer or infinify
(3,997 Views)
"AxE" wrote in message
news:50650000000800000023ED0000-1079395200000@exchange.ni.com...
Use number to fractional string with required # decimal places going to
precision input, then use fract/exp string to number. The first vi will
automatically round up or down.
(3,997 Views)
I also had this problem and used the same method as Adam.
Are there any other ways that are more elegant?
I tried type casting with a control with format specified but that did not work. Matlab has a round function, but I decided it would easier and quicker using the string conversion method.
(3,997 Views)
Multiply with 10^decimal, then round, then devide again. Use an expression
node, with 10**x in it.
Wiebe.
"Nick" wrote in message
news:50650000000500000045BA0100-1079395200000@exchange.ni.com...
(3,997 Views)
Thanks Wiebe. I knew there would be a better way but I didn't have time to think about it.
In the expression node use: int(10**y*x )/10**y
(x is your number and replace y with the number of decimal places you want.)
(3,997 Views)
