how to run VI without the DAQ card connected to the labtop
This may be a silly question but I want to have the answer and couldn't find the answer for spending time in searching in the web.
I want to run the VI that controls the intruments in my labtop. The VI was run in a destop that has a DAQ card in the PC (a PCI card).  I know it is possible to run it without errors (without a DAQ card) in my labtop . Anyone knows how to do it? I used labview 7.1. Thanks,
Jun
(2,538 Views)
If you are using DAQmx and if the DAQ card is supported, you can add a simulated device in MAX.
(2,533 Views)
