I did as you advise, but still not work.
For a more clear explaination:
I attach 4 files (in zip file called esco.vip, pls change back to .zip and open it): one is labview file to open the IE, one is the html file, the other is the .class file of java applet, the last one is the source code of this java applet (for you to recompile and check the safety in case you doubt my .class file about security). Pls put all of them in the same folder
So, if your computer has the JVM, you open the html file using an IE, you will be able to see scroll text runing.
if you open the labview vi, key in the file name, and run it, my home computer can see, but my office computers is not allowed to see (it will appear the grey line). I'm not sure you computer will experience the same (hope you do 🙂 )
So my question is: how to make it running in labview?
I had check the setting and configuration, they are quite similar:
-win XP, SP2
-IE 6
