how to run program without labview software??
how to  run labview software on any other computer which does not having labview software ???????
actually i have made the program in labview software but now our faculty told us to run the program on a hardware nopt containing labview software....
plz sir help me in finding out the solution....as it is the last step remaining in my practical....
Message 1 of 16
(6,715 Views)
You need to make an executable and installer.  The installer will package the appropriate run-time for it.  You will have to make sure to include any other necessary packages in the install.
Bill
CLD
(Mid-Level minion.)
Message 2 of 16
(6,711 Views)
What type of LabVIEW license do you have?
If it's LabVIEW Professional, or higher (or your faculty bought the Application Builder add-on), you can build an executable that uses the LabVIEW Run-time environment.
If your install has the ability, use this.
Cheers
Message 3 of 16
(6,709 Views)
sir is there any direct way to download application builder trial version????
if yes den sir can u send me the link for dat???
Message 4 of 16
(6,654 Views)
You can purchase it fron NI for $1500.
Misread it.  Just download the trial version of LabVIEW.  However, I think the built applications stop working after the trial period.  (I can't remember.)
Bill
CLD
(Mid-Level minion.)
Message 5 of 16
(6,639 Views)
trial version of labview???????
sir i am asking for trial version of application builder??????
i m already using 1 month version of labview..........
Message 6 of 16
(6,626 Views)
Well then you should already have the trial version of the app builder!!!???
Bill
CLD
(Mid-Level minion.)
Message 7 of 16
(6,620 Views)
Have you tried the link i included above????
It will help you if you already have application builder installed.
Cheers
Message 8 of 16
(6,611 Views)
Yes I'm pretty sure you can make an EXE with the evaluation version of LabVIEW, but it will leave the Evaluation watermarks.
Message 9 of 16
(6,554 Views)
Only LabVIEW 7 Evaluation does NOT include the App Builder.  LabVIEW 8 and above Evaluation Versions include it and they have water-marked front panels.  I'm curious if Bilko is right about the EXEs "expiring" along with the evaluation time.  If not, isn't this a way to get free LabVIEW Executables forever without ever actually paying NI a penny?  You would have to code your whole app within 52 days (7 initial + 45 extended) but then your app is free.  Doesn't sound right to me.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9RMSA0&l=en-US
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 10 of 16
(6,535 Views)
