how to save LabView data into diadem format ?
I have a project that needed me to save in Diadem format.
Is it the correct way to save in Diadem format ?
Why the length of the data is only limited to 10000 and then will create another tab ? And how to edit the header name ( what I want is Time,Channel0,Channel1,etc) ?
(2,624 Views)
Your question makes no sense since that VI does not have any TDMS file functions. You are also creating a header in the text file but not according to what you say you want the column names to be.
(2,609 Views)
