how to save a TCP session ID opened and use it in another VI?
what i want to achieve:
   open a TCP session in a VI, save the session ID to Teststand, then after certain process, write/read/close the same TCP session in another VI.
my question:
   1. how to pass TCP session ID between labview and Teststand
   2. how to use the same TCP session across different VIs.
thanks
(2,888 Views)
Accepted by topic author yongjian
You  could typecast the reference to a U32 and sent that u32 to Teststand.
Be aware that the VI that opens the reference should be kept active (=running) or LabVIEW might close the reference silently.
Ton
My LabVIEW Ideas
(2,867 Views)
