how to save a cluster of two elements in excel
I'm having a problem with saving Rainflow count cycles output Value, it's 1D array of cluster of two elements.
Please, help me save it to excel!
Thanks!!!
(3,606 Views)
Unbundle the two elements from the cluster, build them into an array.  Feed that into the Write to Spreadsheet file.
(3,596 Views)
I assume you mean a "delimited Spreadsheet file". A real excel file requires more work.
Just use a FOR loop and "cluster to array" to create a 2D array as follows:
(3,577 Views)
Thank You very much!
(3,569 Views)
