how to save a frame every second from a live vedio in labview
i m using kinesthesia toolkit generate a live vedio, and i want to save a frame every second, how to do?
(3,289 Views)
Assuming you have the appropriate toolboxes, there should be examples to demonstrate how to do this.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,274 Views)
what kind of toolbox is 'appropriate toolboxes'. could you give specific name
(3,262 Views)
The motion and vision toolkit.
Mike...
LabVIEW Champion
(3,254 Views)
i m able to save the frame by using 'write bmp file.vi', but every turn it runs, the bmp file will be overwrite. so, how to make it save to another bmp file and don't overwrite the previous one?
(3,235 Views)
Accepted by topic author 100148X
Well, if you'll notice on the Write to BMP File.vi that it includes a PATH to the file you want to write, that might be a clue.
(3,232 Views)
thanks , i did find a way
(3,210 Views)
