how to save and retrieve 3D data
Hi ccyang,
I ran the VI on my machine about 10 times without hitting the out of memory error (note: I changed the outer loop iterations to 300 instead of 500 because my machine doesn't have enough memory for 500).  If you open task manager and monitor memory usage, does your LabVIEW.exe process reset to a baseline value after the VI completes?  Mine starts at about 382,000 K, jumps to 617,000 K, and then resets to 382,000 K.
Message 11 of 17
(1,733 Views)
Dear Peter, I don't really understand your point. The system cache memory is about 2,080,000 K, and goes to 2,540,000 when I opened LV, goes to 2,200,000 when I ran the example code, and stayed in 2,300,000 after running. Oh, all of these were recorded when I open the internet browser to write these number in this message. Any idea why I run out of memory? Thank you a lot for your effort.
Message 12 of 17
(1,716 Views)
Hi ccyang,
When you open the task manager, click on the "Processes" tab, not "Performance."  Arrange your processes by memory usage by clicking on that column.  Then, watch LabVIEW.exe's memory usage throughout the process.  I tried it again today and generated these screenshots:
Message Edited by Pakman on 09-12-2008 06:27 PM
Message 13 of 17
(1,712 Views)
Ok, when I opened LV, it's about 43,000k. When I loaded and ran the program, it went as high as 430,000k. When the program stopped, it even jumped to 630,000k. After I closed the program, it went down to 48,000k. Hope these numbers make some senses. Thank you, Peter.
Message 14 of 17
(1,701 Views)
Hi ccyang,
What do you observe when you run the program five times?  Does the memory keep creeping higher and higher?  For example, let's say you start LabVIEW and the process consumes 43,000k.  Then, after running and loading the program, the memory stabilizes at 630,000k.  If you keep running the program, does the memory always stabilize at a higher value?   If so, what is the progression (memory levels) until you receive the "out of memory" error?  Does behavior change if you place a Request Deallocation.vi function on your block diagram?
Message 15 of 17
(1,658 Views)
Hi Pakman, sorry for late post to respond to your suggestion. I found that my code always take higher and higher memory. Your suggestion to use request deallocation could be good, but I am not familiar with this function. How to insert this function to my sample? Can you give me another suggestion so that I can test it? By the way, do you think the run out of memory issue has something to do with Windows XP memory management?
Thank you a lot for your suggestion again, and thanks to all who come to help this issue.
Message 16 of 17
(1,592 Views)
Hi ccyang,
You can use the Request Deallocation.vi (Programming » Application Control » Memory Control) anywhere in your top-level VI with a TRUE constant wired to it.  When the VI finishes execution, it will run.  However, I do not think it will do anything in this case.  Your attached VI closes all references, so I do not see how memory is leaking.  Are you running only that test VI in LabVIEW?  Nothing else LabVIEW related is executing when you monitor memory usage, correct?  Also, does modifying the outside loop iterations from 500 to 300 change behavior?
Thanks for bearing with me as we troubleshoot the situation!
Message 17 of 17
(1,576 Views)
