how to save daq data-in(from 2 channels) in 2-D arrey?
Dennis_Knutson wrote:
Yes, you can use the Report Generation Toolkit functions, Write to Measurement File, or low level ActiveX. Hundreds of available examples.
You mean i can use ,i.e Write to Measurement File,instead of right2spreadsheet?  Or i should use both of them? if is it possible or simple for you,could you please show me one of those examples?
Message 31 of 34
(759 Views)
Accepted by topic author Eram
Write to Measurement File and Write to Spreadsheet File create text files which can be opened by Excel. If you want to write a true Excel format file, then you need the Report Generation Toolkit of ActiveX approaches.
Lynn
Message 32 of 34
(754 Views)
The latter versions of LabVIEW and the Write to Measurement File support writing in excel format. It would be silly to use both.
You can search the boards yourself or use Help> Find Examples.
Message 33 of 34
(753 Views)
Lynn
Thank you  Lynn ,for your  good advices.
Message 34 of 34
(733 Views)
