how to save data in labview 2009
I need a botton or a path to save the data. What I have done is that it can save data, but every time after I running the program, it will pop out a dialog to save the data. What I want to do is that using a botton that I can save the data only if I want to save it. Meanwhile, in this program, I have to assign a path before running if I want to save the data. Thanks for answering this question for me.
Message 1 of 16
(4,402 Views)
You need to select your file path before you run your VI.
Message 2 of 16
(4,386 Views)
Yes, I want to save the data after I running the program, do you know how to do it? Thanks so much for you attention.
Message 3 of 16
(4,375 Views)
You are saving the data. If you want the option to not save, place a case structure around the Write to Spreadsheet File.
p.s. Do you know you are throwing away all timing information and cannot reconstruct the waveforms?
Message 4 of 16
(4,368 Views)
Actually, I want to see the diagram first, and then decide whether to save the data. i do not know whether there are others ways to save the data other than write to spreadsheet?
Message 5 of 16
(4,336 Views)
Do you mean you want to see the graph first? The diagram is the code. To look at the graph, just place the print/case statement inside a loop.
You can use any of the functions on the file i/o palette. You can also save to Excel, Word, a database, etc, etc.
Message 6 of 16
(4,330 Views)
Dear Dennis,
What you mentioned above is exactly what I want to do. While I do not know how to place the print/case statement inside a loop. What is print/case statement. Could you show me this loop in a VI. Thanks so much for your kind help.
Message 7 of 16
(4,320 Views)
Accepted by topic author Perry_Liu
You really need to spend some time first with the basic tutorials.
Drop a while loop on a diagram. Place a case statement inside the loop. Place a Write to Spreadsheet inside the true case. Right click on the case structure's selector terminal (the '?') and select Create>Control. Right click on the while loop's conditional terminal and select Create>Control.
Message 8 of 16
(4,311 Views)
Dear Dennis,
Thanks so much for your help!!
Message 9 of 16
(4,305 Views)
Wow, thanks so much, I have spend two days on this and you help me to solve it. Thanks so much, and I have another minor problem. I do not know how to creat a start button. When I push it, it will run, instead of pushing the small run button on the top of the front pannel. Thanks for your answer.
Message 10 of 16
(4,298 Views)
