how to save data (problem about saving data into excel)
Hello
I fixed that problem now I can save the data for one chanel but now I faced
another problem: I can not save data for 8 chanel at the same time, I have
the higher andl lower chanel in the code but when I define them from 0 to 7
(8 chanle) I will get only one chanel:(
I also tried to copy and past the case and in the copy version I set the other chanel
but it does not work becuse each each run should be finnished and then the other one
should be started.
Message 11 of 12
(532 Views)
Hi Kiarash,
I'm looking at the VI, and it seems like you are only passing one waveform with 1-D array of data into the Write to Measurement File VI.  That's only one channel being saved and plotted.  If you want to have multiple channels, make sure the data is merged into a dynamic data type with multiple channels.  You can use Merge Signals under Express->Signal Manipulation.
Yi Y.
http://www.ni.com/support
Message 12 of 12
(506 Views)
