how to save database into format .dbf byLabSQL ?
hello, i made a program for monitoring machine, then the program is saving database to MySQL server. i want to save the database into format .dbf, can i do this on labview by LabSQL ? i`ve tried but not work, i made the table .dbf by FoxPro, i`ve tried save the database into format .mdb and it can work correctly, but i want save the database into format .dbf only. any solution ? Thanks
(3,239 Views)
So instead of MySQL you want to use FoxPro? If there is an OLE or ODBC driver, that should be all that you need. Same as what you've done for the MySQL or jet engine and the .mdb. I have no idea what, of any, changes you might have to make to your SQL commands.
(3,225 Views)
