how to save input and output in file
hi ni
i have program that has some input and some output
i try to save the input and output in file word office or excel like this
error
extended
ideal
value
wq
wp
value
xq
xp
0.857143
0.7
0.6
2
0.5
1
1
thank in advace
best regards
m.s
lab view  2011
hi ?Q>
(2,667 Views)
Accepted by topic author mangood
Read from and Write to Spreadsheet File VIs should do what you want.
I did not take the time to try to decipher what your program is doing, but I think you could replace all those feedback nodes and Build Arrays with an integer data type and the Rotate function from the Numeric >> Data Manipulation palette.  You will still need one shift regsiter or rfeedback node for each of the four signals.
You have duplicated code: Divide by 65535, multiply by 2, and subtact 1 followed by a > comparison.  Make that a subVI and place 4 instances on your block diagram.
Those simple changes will make you diagram understandable, reduce its size to the size of a postcard, and make any future changes easier.
Lynn
(2,658 Views)
Lynn
thank
hi ?Q>
(2,654 Views)
