how to save values one by one into excel usinglabview
I am currently doing work of scanning the resistance from a keithley 2700 DMM. I got the resistance value using single measurement VI. But what i need is everytime i invoke the keithley scan based on a counter signal ,it should give the resistance value. And all these values should get saved in an excel file one after the other along with the cycle number. I am attaching my current VI. Here i got the 2 required outputs, but i could not import them into excel one after the other. Please help me. NB: here i have considered a latched boolean switch as my counter signal.
Regards
Grugh Mike
Success is Everything !!
(3,543 Views)
you forgot to attach vi. Smiley Sad
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,529 Views)
Also, do you absolutely have to have an Excel workbook? This requires using ActiveX to interface to Excel. It sounds like you could use a simple delimited text file just as well. The Write to Spreadsheet File will create a delimited text file that you can easily import into Excel.
(3,506 Views)
I'm using LV 8.2 and I'm having troubles trying to write data to any file.  here is a pic. tryingtowrite.GIF
(3,461 Views)
I am trying to get the resistances of multiple thermistors out of the Keithley 2700 . When a trigger is given, the data need to be measured and taken out. Each and every time i press trigger , the resistance should be measured and taken out. All the data obtained should be appended into a single excel file until i press "stop". I have been trying to do this for a long time, still have not got the required result. Please help me regarding this. I am attaching my current VI, do help me by making the necessary changes. Please. Its urgent.
Regards
Grugh Mike
(3,432 Views)
Accepted by topic author Grugh_Mike
Hi grugh,
First of all put wait in your while loop.
Refer following example as reference.
Let me know if it helps.
Gaurav k
CLD Certified !!!!!
(3,417 Views)
