how to search for a text node with a particular value in an xml document with labview
Hi, Here is my xml doc.
 <?xml version="1.0" encoding="utf-8" ?>
<Cable>
  <Product>
    <Type>FA</Type>
    <Start>1800</Start>
    <Stop>2015</Stop>
    <Mark>1952.5</Mark>
  </Product>
  <Product>
    <Type>FAD</Type>
    <Desp>2.6G</Desp>
    <Start>1880</Start>
    <Stop>2635</Stop>
    <Mark>2635</Mark>
  </Product>
</Cable>
I want to use "get the first matched node" vi to locate "FA" node. The I use "Get node text content" vi to get the value "1800". and I also want to get next two node value 2015 and "1952.5". But my VI is not working. I past my vi diagram here. could someone take some time to look at it? Thanks!
(5,439 Views)
"not working" as in what?
getting different values?
And stop with posting pictures.
A real VI of your work what you need to attach.
(5,416 Views)
<Cable>
  <Product>
    <Type>FA</Type>
    <Start>1800</Start>
    <Stop>2015</Stop>
    <Mark>1952.5</Mark>
  </Product>
  <Product>
    <Type>FAD</Type>
    <Desp>2.6G</Desp>
    <Start>1880</Start>
    <Stop>2635</Stop>
    <Mark>2635</Mark>
  </Product>
</Cable>
First, there is an empty space in front of <?xml version="1.0" encoding="utf-8" ?> that will make the XML parser generate an error.
From what you showed us we cannot know what xpath expression you used with the Match First Node.vi function. FA is already a text node so to match it you should use an xpath expression like //Type[text() = "FA"], this will return a reference to the FA text node. Then you can use this reference with the Get Next Non-Text Sibling to get a ref to the Start node. Continue like this for the Stop and Marker Nodes.
One last advice, close the references that you opened.
Ben64
(5,401 Views)
Thanks! I think that your suggestion is correct. But I write my VI according to your instruction. But it is unable to fetch correct value. Could you please check it.
(5,367 Views)
Accepted by topic author song403
You forgot to add // in front of Type. Close the references when no longer required.
Ben64
(5,339 Views)
yes. I forget //. Thanks!
(5,313 Views)
