how to see communication on specific IP address
I have an IP camera , whose address is known. I connect it directly to my LAN port in my PC.  The camera has its own software for display and control. How can I see the commands passed to camera by the software so that I can control the movement of the camera using Labview. I dont have the command set for the camera. Would that involve sniffing? can it be done by Labview ?
thanks
(2,722 Views)
Typically, you would use something like wireshark. It is free.
(2,712 Views)
What camera? Have you looked to see if it's one that is sorted by NI-Vision?
(2,697 Views)
Wireshark is good one.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,666 Views)
