how to see the full vi of an example
hi
i just want to know how i can view the complete VI of the example.
for instance say i open a blank VI and in the Block Diagram panel   i right click and the ' Functions ' tab appears from which i select ' Arduino '  and then i select ' examples ' and then select  ' servo examples '
this just gives me one block. How can i see the entire VI of that one block?
thanks
(3,774 Views)
What happens if you double-click the "block"?
(3,770 Views)
the front panel opens up
(3,767 Views)
Hi adt,
what happens when you press Ctrl-E on that freshly opened front panel?
(3,756 Views)
Accepted by topic author adt
when you double click the block  you  get the front panel
in that front panel go to ' Window'  and then select ' show block diagrm '
(3,747 Views)
Crtl + E does not work in this case
(3,746 Views)
