how to select particular portion from the spread sheet?
I have 8 color sensor and form that I am getting the informatin as shown  below,
/s0=0 s1=2 s2=4
/////////////////////Sensor 6////////////////////// /////////////
/Sensor_6_rot ?74.08
/Sensor_6_blau ?18.13
/Sensor_6_gruen ?0.00
/s0=1 s1=2 s2=4
/////////////////////Sensor 7////////////////////// /////////////
/Sensor_7_rot ?68.92
/Sensor_7_blau ?12.19
/Sensor_7_gruen ?13.63
/s0=0 s1=0 s2=0
/////////////////////Sensor 0////////////////////// /////////////
/Sensor_0_rot ?63.72
/Sensor_0_blau ?14.06
/Sensor_0_gruen ?13.14
/s0=1 s1=0 s2=0
/////////////////////Sensor 1////////////////////// /////////////
/Sensor_1_rot ?55.20
/Sensor_1_blau ?33.52
/Sensor_1_gruen ?19.53
/s0=0 s1=2 s2=0
/////////////////////Sensor 2////////////////////// /////////////
/Sensor_2_rot ?70.65
/Sensor_2_blau ?16.57
/Sensor_2_gruen ?12.30
/s0=1 s1=2 s2=0
/////////////////////Sensor 3////////////////////// /////////////
/Sensor_3_rot ?67.94
/Sensor_3_blau ?14.50
/Sensor_3_gruen ?12.23
/s0=0 s1=0 s2=4
/////////////////////Sensor 4////////////////////// /////////////
/Sensor_4_rot ?59.74
/Sensor_4_blau ?10.83
/Sensor_4_gruen ?0.00
/s0=1 s1=0 s2=4
/////////////////////Sensor 5////////////////////// /////////////
/Sensor_5_rot ?61.77
/Sensor_5_blau ?22.86
Sensor_5_gruen ?12.90
i wanted to ask how can I select for example sensor 1 and all its data seperatly and same for the other sensor.
because I want to compare the all rot Blau and guen value to detect the color.
please guide me.
Thank youv very much in advance.
Akki.
(3,759 Views)
Hi akki,
search lines containing "Sensor_x" to get data for sensor "x". Then parse the RGB values from these lines…
(3,756 Views)
thank you very much for your reply.
I tryied this vi as in attachment.
but still I am facing problem.
it give me befor value and after value from the spred sheet.
but in my case I want to get value for perticular sensor.
I am using 8 color sensor MCS3AS. I am communicate using VISA.
(3,741 Views)
Hi Akki,
why don't you parse your string array directly?
That's a very basic and straight-forward solution. You can refine this to fit your needs...
(3,731 Views)
Thank you very much for your answer.
this solution is very nice.
could you suggest me that in attached vi How can i reduce the complexity, means how can I modify it in more morden way.
thank you very much once again for you time and help.
(3,717 Views)
Accepted by topic author AnkitRamani
Hi Akki,
You can:
- remove question marks from your input string to simplify parsing the string later on
- use the sensor number as a parameter instead of purely string constants
(3,711 Views)
