09-19-2008 04:54 AM
Hallo,
i have 2 small questions about the intensity graphs:
1- how can i change the color of the intensity graph?
2- is it possible that i can select some parts of the intensity graphs using the cursor for example?
thanks..
09-19-2008 06:53 AM
Hey,
1 - there is a property called "color table" which provides an array of 256 elements defining the colors
2- you can use the cursors in the same way as with a signal graph. so right click the chart > visible items > cursor palette,
then right click the cursor palette and create a new cursor
Christian
