how to select two strings and send to a serial write using case loop
Which 3rd party software you are using for USB to UART bridge i.e. usb to DB9 conversion ?
Are you sure that is configured properly ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 16
(1,145 Views)
Thats why i asked him this question and still he hasn't replied Smiley Wink
--Ranjeet
Message 12 of 16
(1,145 Views)
It has nothing to do with the hardware, crossrulz is trying to tell you this: http://digital.ni.com/public.nsf/allkb/49D72E8658F6AEE48625758A00710BB4
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 13 of 16
(1,137 Views)
Hi .aCe.
                      It has to do. when usb to serial software is installed then it will assign the usb to one com port like com3, com4 etc. I just want to assure this is first.
--Ranjeet
Message 14 of 16
(1,134 Views)
I was just trying to re-iterate what crossrulz was saying that's all. So you may never get and equal condition.
Message 15 of 16
(1,124 Views)
these are two conditions to be drawn in the same graph. So the values in graph have to continue , when one of the given cases is true. Thus only one basic serail write and read I can use. So the write should not work when both of this condition is false when one of it is true, (=0.01) the write should take +500 and the same write have to write -500, when the condition is equal to -0.01 , is it possible. Please help
Message 16 of 16
(1,105 Views)
