how to send 1-D array of waveform(DBL) over UDP
i am acquiring voice data in the form of 1-D array of waveform(DBL) and wants to send it over UDP and receive again at other end.(labview 10.0)
1.how can i convert it into string for UDP sender?
2.at receiving end how can i again convert it into original form?
i have attached vi files
in sender combinations are:
1.sample rate: 4000
2.number of channel: 1
3.bits per sample : 8
5. ports will same at sender and receiver(port 2600)
and receiving end also same
(3,418 Views)
Flatten to String and Unflatten from String.
(3,403 Views)
it seems there is more than one student working on the same problem
You really should team up!
(3,392 Views)
