how to send an email from a VI
Hello..
      there is one example E-mail notification.vi in example finder. there is an option for testing smtp server. There is no problem with smtp server.
But, I got an error
Error 16502 occurred at 502 5.5.1 Unrecognized command. 12sm591346fgg.15
 What is this error?
Message 21 of 50
(4,059 Views)
Hello david
 thanx for sending ur VI. But it latest version. I have Labview 8.6 . Can u send 8.6 version VI.
Message 22 of 50
(4,050 Views)
Error 16502 means the command has bot been implemented. !  Can you post the VI or a screen shot?
Richard
Message 23 of 50
(4,050 Views)
As the poster indicated, the VI is from the Example Finder.
Let's try something simple.  Take the attached VI, enter the mail server, and the recipient. What happens?
Are you sure your SMTP server does not require authentication.
Message 24 of 50
(4,041 Views)
Hello broken
thankx for ur reply
here I attached vi. I amgettinng following error
Message 25 of 50
(4,039 Views)
By the way, is this an internal, or external SMTP server that you're talking to? Do you know what kind of SMTP server it is? Is it an Exchange server? Also, are you sure that the server uses port 25 to receive emails?
Message Edited by smercurio_fc on 09-16-2009 02:07 PM
Message 26 of 50
(4,032 Views)
Hello smercurio
  I tried  test email.vi.  I got this error
error code:16502      source: 502 5.5.1 Unrecognized command. 3sm178358fge.4
here, I attached a picture of front panel
Message 27 of 50
(4,026 Views)
What is internal server and what is external server. i am not aware of it.
Message 28 of 50
(4,023 Views)
how to check the authentication of smtp server.
Message 29 of 50
(4,021 Views)
Yes here is an 8.6 version
Message 30 of 50
(4,018 Views)
