how to send data from one vi to another Vi if sub vi is runninga while loop but main vi is waiting for the response
The above image is for the SUb vi code there i am running the while loop but when the response indicator is getting the value but in main Vi i can't get the data is there any other way except using of global variable
(1,263 Views)
Hi Siva,
You already know how to use queues so what's the problem to use one more queue?
(1,255 Views)
There no problem with queue but I am seeing there is any better way to send the data i found Notifier i am using that which you will prefer in b/w Notifier and Queue
(1,245 Views)
Hi Siva,
That depends on your requirements.
What are your requirements regarding "number of data sinks" and "number of data sources"? That's how queues and notifier differ (basically)…
(1,243 Views)
I need a synchronizing operation so that is why i went for the Notifiers.
siva
(1,220 Views)
Hi GerdW,
I need a synchronizing operation so that is why I went for the Notifiers.
Siva
(1,218 Views)
Accepted by topic author Siva1103
Hi Siva,
Usually queues allow for syncing producers and consumers…
(1,205 Views)
