how to send more then one data via tcp
I am working on a similar project to send multiple data from a DAQ card via tcp, but i just cant seem to get it to work. I am still a begineer with LV so not sure how to handle the problem, there are no errors but the client graph shows nothing. i had tried the recemended methods in this forum but havent been able to solve the problem. Some sites suggest using Data socket instead, so should i start using data socket ? or can it be done using tcp?
Message 31 of 43
(1,647 Views)
Hi Jeshua,
can you show your vi? I'm sure it's possible with the tcp/ip functions.
Mike
Message 32 of 43
(1,641 Views)
thanks mike for trying to help me out. Please have a look at the attached files. I have actually, replaced the daq assistant with a three waveforms and to make it easier to work with i have both the server and client in the same file.
thanks
Message 33 of 43
(1,636 Views)
You are flattening an array of waveforms.  But when you unflatten them up top, you defined it as an array of doubles.  Right click on the thick brown wire going into your Flatten into String and pick Create Constant.  Move that constant to the top half of your code.  Delete the empty array of doubles and wire in the Array of Waveforms constant you just moved up there.
Message 34 of 43
(1,627 Views)
hey,
Thanks for your suggestion, please have a look at the file to make sure i used it correctly. However, the graph is still not displaying anything.
Message 35 of 43
(1,623 Views)
What you are doing seems correct.  It isn't working for me either.  The TCP part is working just fine, it is something about the unflatten from string liking the array of waveforms.  I don't know what it is though at the moment.
Message 36 of 43
(1,613 Views)
You need to wire a false constant to "data includes array or string size" on the receiving end.  See discussion above.
EDIT: after testing, I think that's part of the problem, but it still isn't working even with that false constant.
Message Edited by nathand on 08-21-2009 03:00 PM
Message 37 of 43
(1,607 Views)
I tried that too.
Without the false constant, it doesn't unflatten, but doesn't return an error.  (Put an error indicator on the Unflatten function since automatic error handling was disabled.)  Put in a false constant and you get error 74.
Message 38 of 43
(1,598 Views)
I got it working; turns out my last reply was almost the right idea.  Try removing the False constant from "prepend array or string size" on the sending side.  For some reason, it appears that unflatten from string works better for arrays of waveforms when the array size is included.
Message 39 of 43
(1,597 Views)
Dohhh!!!.  I should have seen that.  I thought I was looking for that on the sending side as well, but I must have gotten distracted before I did.
Message 40 of 43
(1,591 Views)
