how to send multiple data from arduino to labview by using ethernet shield.
hello,
i need to send multiple sensor data acquire in arduino to labview by using arduino ethernet shield.
I tried UDP and TCP  protocol but i am not able to get all the sensor data their is loss in data package. Is any possible to get all the data without loss by using labview or Is their any other solution to send data arduino to labview  using ethernet shield and LAN cable.
(3,159 Views)
TCP is the route to go.  We would need to see code to evaluate any other possible issues.
(3,152 Views)
Hello Balaji
Refer this thread.
Try using LINX/LIFA toolkits for making your job easier.
-Rahul
Hit KUDOS for Thanks
(3,139 Views)
thanks for the reply,
Is it possible to acquire sensor data by using I2C communication in LINX/LIFA. Is their possibility to provide any example code for arduino and labview.
(3,114 Views)
Yes, I2C is available in LINX toolkit. Install LINX toolkit from VIPM or download from MakerHub website.
In the NI Example Finder (Help->Find Examples),search for LINX examples, you will get everything you possibly need.
Hope this helps !
-Rahul
(3,053 Views)
