how to send text to cluster with boolean LED's
Hello, I want to ask for some help. I am making such program which must send text, which I enter to string box, to clusters that are filled with boolean (Round LED). 4 clusters with 6x8 boolean in each. I need that this text would be shown on these booleans (smth like display made from them) and that the text flow out to the right. What conversions needed to be done to get this text shown like that. If possible say easiest way to do this without coding each letter. And would be nice to see some example with one letter. Thanks in advance.
I am using Labview 6.0.1, but I have labview 8.5 too.
(2,788 Views)
Check out this example, written by one of the developers in LabVIEW R&D.
You won't be able to use it in LabVIEW 6, since it uses XControls, but you should be able to recreate the relevant code.
___________________
Try to take over the world!
(2,767 Views)
Thank you it looks like exactly what I need exept the version, but I try to be smart and remake it 🙂
(2,759 Views)
