how to send the data from Labview to Arduino
Hard to debug.  You didn't attach any of your Arduino code to show how that is programed.
Message 11 of 21
(3,265 Views)
This is my Arduino Code
#include <SoftwareSerial.h>
int incomingByte = 0; // for incoming serial data
void setup() {
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
void loop()
if (Serial.available() > 0) //See if data is there
incomingByte = Serial.read(); //Read a byte
Serial.print("I received: ");
Serial.println(incomingByte); //println appends the termination character
Message 12 of 21
(3,264 Views)
Remember that you can't have both LabVIEW and Arduino IDE open at the same time.
Before you run your LabVIEW program, you need to close the Arduino IDE debug window. Only one of them can use the COM port at one time.
Message 13 of 21
(3,255 Views)
@kavyatweetee wrote:
Sir I modified my program in Arduino and also changed my VI but the output in Labview seems to be null. It is neither showing any output nor error in Labview.
I have to ask the stupid question: Did you press the Send button?  That Event Structure is sitting there waiting for you to do something.  One of the things it is waiting for is for you to press the Send button, which will make the LabVIEW code then write to the port and read the data back.  The other thing the Event Structure is waiting for is for you to press the Stop button, which will cause LabVIEW to close the serial port and end the VI by stopping the loop.
Message 14 of 21
(3,249 Views)
Good morning
Yes sir I did that and it is working but after pressing the stop button in Labview, I started seeing the output in Arduino but nothing comes to it.
It is also not showing that Arduino port busy and the output is also not coming in the "serial port". Can you please tell me why this happens with Arduino.
I used the same Arduino code which I given to you before in this discussion.
Message 15 of 21
(3,231 Views)
When you press the Stop button, the VI should have stopped running.  Therefore nothing should be being sent to the Arduino.
Message 16 of 21
(3,226 Views)
If you press send and the data gets sent to the Arduino through the VISA Write, the code will then wait at the VISA read until:
1.  It receives the termination character
2.  It receives the 50 bytes your requested
3.  It times out.  (usual default is 10 seconds)
So if you aren't getting data, you must be getting #3.  Are you getting time out errors?
Message 17 of 21
(3,224 Views)
Good morning
 Firstly I want to tell the process that I am doing. I start with uploading my Arduino code to Arduino UNO Board and then I am opening my Labview code and I run that VI and I am getting the output in Labview(It is reading data from Arduino). Next I am opening the Arduino "Serial monitor" and it is showing the "PORT BUSY" error and I am not getting any time out errors also.
Message 18 of 21
(3,207 Views)
You can't have two different programs accessing the same serial port.  Once one opens it, the other program is locked from using it.  That is what "PORT BUSY" means.
Message 19 of 21
(3,203 Views)
Now what is the solution for this sir????
Message 20 of 21
(3,200 Views)
