how to set AO channel to 0 value when VI stopped
when a VI stopped, the AO channel stopped on the level it's get, how to set these analog output to zero when stop a vi?
(3,127 Views)
Just do another DAQmx Write in your stop event or place it outside your while loop.
(3,123 Views)
Hi!
As a second option (and if your device supports it ) you could set the property "Idle Output Behavior"
see here:  http://digital.ni.com/public.nsf/allkb/dc9d2ab6dfb1924e86257260000cc350
and here: http://forums.ni.com/t5/LabWindows-CVI/Analog-output-behavior-after-the-task-has-stopped/td-p/655137
Marco
(3,110 Views)
is there a list of which devices support AOIdleOutputBehavior ?  thanks.
(2,952 Views)
