how to set current data as default when stop VI automatically?
Each time, when I finish a VI, I want it remember all current value so that I can reuse it next time. I want this can be done by program itself.
Any idea, thanks
(2,295 Views)
If you are using LV 8, there is a built in function to perform a "make current value default" at end of you VI.
If LV 7 and older there are some tricks, that have been explained and re-explained on the forum, so do a search with "make current value default" and you'll find all you need.
Hope this helps.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,290 Views)
