how to set password and user by using CGI
hi
I have set up the web publishing.i can browse the vi throught IE.But i want to set the password and user by using cgi to be more security.And peopple need to login with correct password and user when it want to browse it. I know the G web server can do this,but i cannt do it even i follow the instrustion. I have problem in give the VI path into the G web server. And there is problem in seting the password and user too.
Can anyone can help me.Thanks
(2,668 Views)
Here's the information I posted to the other page:
"To set up configuration access to a VI panel image, you will need to set up a global access configuration file (*.cfg). There are numerous CGI shipping examples that are included with the Internet Toolkit. To access these examples, first start your G web server. Then, in a web browser, type in http://localhost (if you are not using port 80, you’ll need to type in a colon followed by the port number in the URL).
The localhost url above should direct you to the default homepage for the G web server. Make sure the title is “G Web Server” and not “LabVIEW Web Server.” From the G web server page, you’ll see a button to “View CGI Examples” and from there, you’ll see a category titled Access Control. Just so you know, the hard-coded path to this page on your computer is: C:\Program Files\National Instruments\LabVIEW 7.1\www\examples\access.htm. There are then examples on setting up access control for panel images as well as directories. The sample configuration file is: C:\Program Files\National Instruments\LabVIEW 7.1\internet\http\conf\access.cfg
Hope this helps. Best of luck!"
Kileen
(2,654 Views)
