how to set start time of wave form chart
Dear Friend
i want to show wave form start time when i run the program. and it should save wave form for at least 48 hours.
Asif
(2,615 Views)
The Waveform Palette has a Build Waveform function (which is basically a Bundle-by-Name, a function you could also use).  The Timing Palette has a Get Date/Time in Seconds.  Combine these and you have (except for the 48 hours of data) your solution.  Oh, don't forget about the "dt" component ...
Bob Schor
(2,594 Views)
And where is this waveform coming from?  What is your sample rate?  How many channels are you capturing?
(2,582 Views)
