how to set the pulse amplitude?
Hi
I am using the example VI attached below to generate a finite number of digital pulses using the NI-PCI-6601 card.
I want to set the amplitude of these pulses to 5 volts. how can I go about doing this?
Regards
Shab
(2,534 Views)
The counter output is TTL compatible so you don't have to set anything (and can't set anything).
(2,521 Views)
Very true. Since it is TTL logic, you need not worry about it. Hope we got your question right and you got the solution for that.
Pavan
(2,490 Views)
