how to set time in cRIO 9004. will it affect the time setting if power fails momentarily
how to set time in cRIO 9004. will it affect the time setting if power fails momentarily.
(2,570 Views)
25806181,
You can easily set the time on the cRIO controllers by using the RT Set Date and Time VI.  This is located in the Real-Time VIs >> Real-Time Utilities palette.  Once you run this VI on the controller it will retain the time you have set for it, even after a power failure.  Hope this helps!
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,561 Views)
