how to set word Graph X axis coordinates location
I use the Report Generation tools to insert a Graph Plotting displayed on the Word , the following chart (1)
Problems :How to put down X axis coordinates of the following, from Report Generation were no related tools, not aware of any other method, the manual only know that the plan is as follows (2)
(2,973 Views)
Hi, fong_ui:
There is a VI named
"Word_set_scale.vi"
inside
..\National instruments xxx\VI.LIB\ADDONS\_OFFICE\_WORDSUB.LLB
That is called to set the scale of a chart.
If you open it, you will see that only "minimumscale" and "maximumscale" are set.
You can add another property, named "CrossesAt" and set it's value to "minimumscale"
Notice that if you change and save this VI you will be modifying ReportGenerationToolkit, so every VI that call to "Word_set_scale.vi" will follow the modified version.
Hope it helps,
Aitortxo.
(2,959 Views)
It helps me so much, Thanks!
(2,559 Views)
