how to setup a queue with a multiple unit tester
Is this your top level VI or just a VI to control what to do next? If its your top level VI you shoudl convert it to a State Machine. Otherwise, force program execution with the error line and SubVIs, not a sequence structure. Sequence structures are not very scalable and they take up a lot of block diagram realestate.
Making that change will help making what you are tryng to do easier.
Message 11 of 21
(1,547 Views)
Okay, I set it up as a state machine, now how do I create a button to start the vi without having to use the 2 button dialog boxes?  See attached.
Message 12 of 21
(1,537 Views)
HAve you used an event structure before? I think this will be your best bet to get your state machine running without the two button dialog box. Instead of polling for an input like you are doing, it uses event driven programming. You can set up a boolean called "Start Tests" and monitor for a value change on that boolean in your event structure. Then, based on what button is clicked, you can enqueue the proper states and take the proper action. Article on event driven programming: http://zone.ni.com/devzone/cda/tut/p/id/3331
Your event structure will live in a "Monitor" state where you monitor for inputs. Maybe you'll set it up so that you have a "Test 1" and "Test 2" case. When the "Test" boolean is clicked you'll go to the Test 1 case, and then go to the test 2 case. And then back to your monitor case. Maybe you'll save your data in which case you'll go to a Save Data state after Test 2.
Does that help/make sense?
Message 13 of 21
(1,533 Views)
Yes, but don't you need to have the full developement system to use event structures?  I am using base developement!
Message 14 of 21
(1,531 Views)
Oh... you're right about that. Maybe you can just poll a boolean called "start test" and watch for a value change through the polling. To know if the last unit passed or failed you could use a pass/fail boolean instead of using the dialog.
Message 15 of 21
(1,526 Views)
Thanks for all your help
Message 16 of 21
(1,519 Views)
I think this is more like what you want as you discussed. This uses semaphores.
Message 17 of 21
(1,503 Views)
Message 18 of 21
(1,501 Views)
I think I got everything all figured out now thanks, I didn't end up using a queue or semiphore!  Feel free to check it out.
Message 19 of 21
(1,496 Views)
Would love to, but I am currently using LabVIEW 9.0. Can you save it for earlier version?
Message 20 of 21
(1,494 Views)
