how to show number in hexdecimal format of given length
Hi all,
  I want to show a 32bit number in hexdecimal format. In the number control, right click menu and I click into the "Display Format", I can change the format to hex. But I wonder if there is any way to show the hex number with given number of places holder. In C language, I can plot the number as
printf( "%.10x", number)
so to keep the result for total 10 places. I find an "advanced editing mode" in "Display Format" but I didn't get the "%.10x" work. Any idea?
(3,274 Views)
Accepted by topic author PKIM
Hexdecimal number are integers, so there should be no period in the format. You don't need the advanced format.
SImply set the format to hexadecimal, set a minimum field width, and pad with zeroes on the left.
(3,246 Views)
A 32-bit number can only be represented by 8 hexidecimal digits.  So I would use %08x for the format.
(3,182 Views)
