how to simulate a ramp signal and an on-line graph
I am considering to simulate a ramp wave for my application which is used to load a tension test apparatus. I am currently not able to simulate it, since LabVIEW 7.1 only has an option of simulating sine,triangle,square etc.
Kindly reply me with the earliest.
I am having one more problem. I am currently having 2 dynamic datas and I need to display an online graph of these 2 variables. Please help. I do not want to fit any data, but I want a online raw data graph.
If not possible can I use DDE to transfer these data online to excel and get the graph?If so HOW?
Please guide me wichever is easier.
Awaiting for your reply,
With regards,
Dasharathi.M.S,
Project Scientist/Engineer Trainee,
Structural Integrity Division,
National Aerospace Laboratories,
Bangalore-17,
INDIA
(3,060 Views)
find attached a "reduced vi" - I have removed all of the driver parts
from KEITHLEY K2400-SMU. This instrument is very useful for
Voltage- or Current-ramping.
Have a look to the "sweep values" sub.vi - this vi
creates the values for these ramps (linear/logarithmic /binary and arbitrary)......
simply test it.
The picture in zip-file shows, how Diodes are evaluted with this program.
This is my answer for first part of your question.
Hope this helps.
Regards
Werner
(3,053 Views)
A sawtooth signal is a ramp signal once you add a DC offset to it to make it all positive.
Randall Pursley
(3,040 Views)
